I'm looking for some opinions on what people would recommend for a NAS setup.
I'm picking up a QNAP TS410 NAS tomorrow (4 bay) and I'm having a bit of dilemma on what drives to pick. It seems like every single drive out there has some fault and short of forking out big money for the RAID editions of the drives, I'm not sure what the best choice is.
I've chosen the 1TB drives since they seem to offer the best value for money price point at this time. I could go 2TB as well, but from reading reviews on Newegg, etc, it seems that maybe 2TB drives aren't quite mature yet and seem to have an unusually high failure rate no matter what drive you look at so I'd like to keep away from those for the time being.
The options I've found locally (in Vancouver BC) at NCIX that were reasonably priced:
Seagate ST31000528AS ($69.99) 1TB/7200rpm
Western Digital WD10EARS ($69.99) 1TB/5400rpm
Western Digital WD1001FALS ($85.99) 1TB/7200rpm
Seagate ST32000542AS ($109.99) 2TB/5900rpm
The 2TB Seagate I just put in for comparison sake so you can see the pricing.
From the research I've done, it seems that the WD10EARS has the ability to change the head park time with WDIDLE so that clears up the excessive 8 second head park issue. No TLER option is available for this drive as far as I can see.
The next one on my short list is the Seagate ST31000528AS. Correct me if I'm wrong, but I won't see any difference between 5400rpm vs 7200rpm because the NIC will be the bottleneck. (although I do have a GigE network) Is it fair to not even consider the rpm difference as a factor? 7200rpm drive will probably run hotter so that's a negative there. The only plus side is that I have a few 7200rpm drives in my machine already and I can probably salvage at least one drive from my PC to put in the NAS. Saves me having to buy one extra drive. Apparently, ERC cannot be disabled on this drive either (Seagates implementation of TLER).
If rpm makes no difference, then the WD1001FALS is definitely out since it wouldn't make sense to pay an extra $15 for not much performance benefit.
The 2TB Seagate comes in a little cheaper than 2 1TB drives. I guess I just don't feel comfortable after reading reviews on any of the 2TB models. There seems to be a lot of complaints about clicking and failures. 2TB is a lot to lose. Not sure I want to risk it but if my assumptions are incorrect, then I can get over this fact.
So what are people's thoughts on this? What do you think my best option is? Go with the WD Green drive, or get the Seagate Barracuda 7200.12 drive? (or take the Seagate 2TB drive and go all out?)
