I'm upgrading a computer I put together a few years back. It's has an Asus A7V8X-X motherboard. I'm adding a Western Digital EIDE 500gb drive to it (upgrading from a dying 120gb).
I updated the bios of the mobo with the latest non-beta release, 1013 from 2004.
So, I installed the drive and it's not detected in POST. While booting it show a blank space for the Primary Master, "None" for pri slave, "None" for sec. master and the DVD drive for sec.slave
After it goes through the drive check an error shows that there is no primary master, press F1 to continue or DEL to enter the bios setup.
Ok, so now I've tried pressing F1 with the Windows XP home install disk inserted. It will enter setup, detect the drive in the install and will go through the entire installation Windows installation process. When it comes to rebooting, the drive still doesn't show up in post and if I take the Windows disk out of the drive the computer will not boot due to no drive being present.
The diagnostic tools that also came with the new drive do show the drive. It can format it, run maintenance checks on it, etc. It's just the bios that doesn't see it.
I'm chalking this up to the motherboard being manufactured before drives larger than 127gb were not supported at the time, though I thought that the BIOS update would fix that. I also think it's strange that the Windows install can work with the drive, as well as the diagnostic tools.
Another note: the old 120gb still works fine. I think the partition table had an error. A new format and fresh install of Windows and it runs fine. The drive is going on 3 or 4 years old though and I'm not trusting it, hence the reason to upgrade to the 500gb. Point being, I don't think it's a cable or fried controller issue.
Any suggestions?
Any suggestions?
