Well i was able to FINALLY get my new system setup (specs in sig) and windows installed fine with no problems. However, i can't seem to get the mobo drivers to install, the ones on the CD i got don't work (don't know what version they are though) and i tried to use the latest 6.66 drivers, but to no avail.
Basically what happens is i install the drivers and restart the computer but no matter what when the XP load screen comes up it just sits there. So i restart the comp and windows asks if i want to go in safe mode, i did and i unistalled the drivers, restart again, and windows loads just fine...i did this both when i installed the drivers from the CD and the 6.66 drivers (they may be the same, i guess i should check)...
anybody got any ideas? i'm about to go back and try some other things but i'd like to know if there is an easy solution to this..
BTW i have a Rev. 1.02 with 1011 bios on my board....
EDIT: Problem solved
