So, I finally got my computer going. During the entire setup, I was using 2 gig of memory.
After I was all done, I went ahead and installed the other two (same brand/speed). Windows won't boot. I kept on hitting the reset till it finally did. Checked the system info and it showed 3.7 Gigs. I was very happy.
Well, that was short lived. It keeps having the same problem. With 4 Gigs, when I hit the power button, the fans kick in and I don't hear any beeps and windows never starts. As soon as I pull 2 gigs (leaving 2) Everything is fine.
Now, I had asked this before I bought the memory.
I am running Windows XP SP2 32-bit
I was told it will not see all 4 gigs, which was fine with me, since at least I'll be prepared when I go to Vista. But I never thought it just won't start.
Any ideas? Is this the norm?
Spec:
CPU: E6550
Motherboard: Gigabyte DS3L
Ram: G Skill 1x4 Gig DDR2 800 mhz
Thanks
Spec:
CPU: E6550
Thanks
