My parents computer is having memory problems. It is an old P4 Northwood 2.6Ghz on an Abit IS7 motherboard. They had 4x256mb PC3200 DDR modules on the board, but one of them went bad. If I take out the offending module, the motherboard will go back to single channel memory with 768mb, and if I take out two modules, the motherboard will be dual channel, but with only 512mb of memory. Which one of these would be a better idea for use with windows XP?
I intend to replace their entire computer in the near future, so it doesn't have to be a long term solution, but I would like to get the best possible performance in the mean time.
