I ordered a Xigmatek heatsink from newegg and when it came i saw that the box was mangled. The bottom right corner was crushed and even the plastic window was split open. So I called newegg and to my dismay...they sent me a replacement one for for free and let me keep the damaged one i have.
So now i'm stuck with two of these heatinks and was thinking that I could just use two of the included fans on one heatsink? Would that make a big diff at all? How should i set the fans up? Both push the same direction...both pull the same direction? Also do mobos have more than one PWM connecter by the cpu area?
I could always sell the damaged one for cheap if it's not worth to run two fans. Only 7 sections of fin bent and easily fixed.
