I have already troubleshot this to death, so I thought I'd see if anyone could help me out.
I have a 3 monitor setup and until recently have been using the following hardware:
Proc: i7 860
Mobo: Intel DP55KG
Ram: 16 gigs G.skill
Primary Graphics: EVGA GTX 470
Secondary: Reference 8600 GTS
PSU: OCZ ModXStream 700 watt
I ran the secondary card in the 3rd pcie slot at the bottom, and everything was fine.
I decided to upgrade to SLI 470s because i found a deal on another, even though it was a 470 SC. So I updated the following:
PSU: Seasonic SS-850HT
Secondary: EVGA GTX 470 SC
I put the new card in the proper slot for sli, and tried all orders and combinations of driver uninstalls/reinstalls but no matter what the output would go to the SC regardless of whether it was in the first slot or second. I did a mobo bios update, and they both magically started working, but upon turning it on the next day, same deal. No matter what i tried i could not get the non sc to show up in windows while the SC was present.
So i swapped in the following:
Proc: i3 540
Mobo: MSI P55-GD65
Same deal, but the BIOS update trick didnt work this time. Ended up downloading an update for "Realtek PCIe GBE family controller" through windows update, and after the reboot, Everything worked. I had had my pc on for a couple of weeks since then, but there was a power blink last night, and my non SC was once more unrecognized. I have tried cleaning out those realtek drivers and reinstalling, but alas, it wont solve my issue. I also decided to flash a SC bios onto my non SC to see if that was the issue. the card with the flashed bios works fine by itself, but once more if the SC card is present, it will not show up in device manager in windows, or output on any display hooked up to it. have tried all combinations of graphics driver cleans/reinstalls with all combinations of cards in slots at different points during the process(one at a time, both at the same time, etc..) When both have been recognized in windows, sli works fine, and i can switch between sli, surround and multi monitor mode fine.
TL; DR: I have 2 GTX 470's and am only able to get one to display in windows at a time.
Feel free to ask any questions if I am unclear about something. Once again, I have thoroughly troubleshot this and it is not a mobo or graphics card problem. Something is up with windows I'm guessing.
Proc: i7 860
Mobo: Intel DP55KG
Proc: i3 540
Mobo: MSI P55-GD65
