seniorpaul
- Aug 8, 2005
i'm in the process of planning out a fairly extensive project. It's basically going to be an external box to house watercooling equipment that is going to sit on top of my case. Since i'm going to be modding this myself, i figured that i would have the unit serve a couple of other purposes. I'm planning on having a docking station for my Ipod built into the top, the audio controls for my speakers built in somewhere, and i'm toying with the idea of an LCD screen on the front that would display system information (temps, etc....).
I currently have a OCZ PowerStream 520, and it powers my system fine (the one in the sig below along with a couple of optical drives), but i plan on adding a second 7800GTX and a few more HD's in the next few months. Add to that my water pump, around ten 120mm fans, and a couple of things that are going to require power for my mod (lcd, etc..), and i'm not sure my OCZ is going to be able to hold up.
Sooooo...I could go get a PC P&C 850W SLI PS, but what fun would that be (and i can't don't want to drop the money). Instead i think i'm going to throw a second PS in there (probably another OCZ 520 that i could get for cheap from a friend). I've found a couple of places that show how to connect a couple of power supplies with 20 pin MOBO connectors so that both units power up when the computer is started, but i'm wondering if anyone has done it with 24pin connectors. I've found the diagrams showing what each pin is for, so i'm fairly confident i could figure it out, but wanted to see if anyone had done it already.
