I recently got myself a good TV, and until I can afford to build my HTPC I have been lugging my main one in and hooking it up to watch movies ETC.
System Info;
My DVD Drive is a basic Sony 16x DVD Rom.
DFI NFII Ultra B and 2Ghz Athlon proc. 1GB of PC3200
BFG 6800GT oc for DVI out (latest drivers)
Software players;
PowerDVD 6
ZoomPlayer Pro
Problems;
With Power DVD I had the video to playing fine but there is a little pixelation and "cryspness" issues that I can live with. What I cannot live with is the artifacting and lag outs that I get every few seconds. Some lag is not too horrible and corrects itself quickly. But at times it will pause the playback for a few seconds before resuming. The audio runs perfectly through the S/Pdif out unless its one of those few second lag outs.
At first I though it was just the cheapo DVD Rom, but then I loaded up ZP.
With Zoom Player I went in and selected the PowerDVD dvd Decryption for video and Audio, for the audio renderer the onboard NVidia (have tried default direct sound but Nvidia sounds better to me) Under Additional Filters I put in the FFDshow Video Processor to force movies into the 1080 resolution and run some clean up on the video.
As ZP is less intensive it has seemed to clean up all lag and artifacting with movie play back.
And for my tests it worked perfectly testing full DTS es and video quality on Return of the King. After a few minutes I close ZP and pull up PowerDVD to check the difference. Power DVD now will only play audio and no video. Pulling ZP back up it keeps giving me Filter error's no matter the combination. If I remove FFD Show from the list it will go through and play about half of the time but the video quality is lessond now as well as audio. Power DVD will still not play any video.
If I remove everything and put it all back on it will work minus the FFD Show, for some reason ZP refuses to work with that now and once I try PowerDVD loses its video playback. I am planning to buy the pro version of ZP and get off the trial but cant pay for it at the moment. Could that be whats causing my FFD show problems? While playback in ZP is better without the FFD show tweeks I might as well go back to using my PS2 as a DVD player.
Also what DVD players do you reccomend (hardware) as well as software filters?
Sorry for the really long post but this has been agrevating me for a few days now and finally have given up.
System Info;
Software players;
PowerDVD 6
ZoomPlayer Pro
Problems;
