Here's a tricky question, but I figure if anyone can answer it, it'd be the [H]ard community. It's a little difficult to explain, but hopefully my point comes across.
At my workplace, I have a laptop dock that has both a DVI-D and RGB video out for a monitor. I'm currently using the RGB out for my LCD monitor (it's the only input it will accept) and I'd like to use the DVI-D for a second display.
Right now I have a DVI-I to RGB adapter. If you follow the following two links, you can see the difference between DVI-I and DVI-D is 4 pins next to the plastic key:
DVI-D
DVI-I
So here's my two questions:
1. Does anybody know if a Dell Laptop dock will allow dual display?
2. With the DVI-I to RGB adapter, can I remove the four pins and have it function as a DVI-D adapter, or is there internal wiring that prevents me from doing this?
DVI-D
DVI-I
