Hey guys,
I just upgraded my computer and thought I would post my results with my new gear. I'm currently running the following:
Intel C2D E6600 L640A773 - 80557E6600SL9S8
eVGA 680i P25 Bios
G.Skill 6400PHU2-2GBHZ
Zalman 9500 (No Led)
Cooler Master Wave Master
Enermax Liberty 620W
vNvidia 8800GTX
Creative Audigy 4 Pro
Ok, eveything runs great at stock speed and I score 9,998 in 3Dmark06, yay. I think multitasking is a tad more responsive when I get a lot of tasks going than my old 4400+ X2. After about an hour of "wow, this is great" I start my journey down OC lane. It's been rough. I was able to get the computer to post at 3.9GHZ and if I se the vCore to 1.55 I could almost get into windows but it would blue screen everytime. So I started backing it down and found that I could get into windows and do regular tasks at 3.6 1.45v. The problem is it's only stable in Orthos for about a half an hour. For those of you that are wondering, my temps are 43c idle and 64-67 load for the CPU and 33c for the system (according to nVidia Montitoring utility). My case is running 2 Thermaltake 80mm Tornados (those orange screamers @73CFM) for the rear exhaust and top intake. A 92mm panaflow side intake at about 54cfm and two 80mm front intake fans from coolermaster that came with the case.
I have a lot of work ahead of me when I get home tonight and I think I may have to play with ram, SPP, MCP and HT voltages. Currently SPP is at the max, MCP is by default running at 1.5, and HT is at 1.25 and there is room to go a little higher on that setting but I don't know how much of an impact that will have and what is the safe max voltage for it. I remember my old rig would crash like crazy before I upped the ram voltage a tad from 2.2v to 2.3v and then it was stable and that was at stock speeds so maybe it's as simple as upping the voltage on the ram. It's rated for 2.0 to 2.1v operation. I have it running at 2.0v currently. The timings are 5-5-5-15. I haven't tried tweaking the ram yet. I want to get a stable CPU OC first.
Anyways, I was curious as to what voltages some of you are using when OC'ing your E6600 with an eVGA 680i mobo. Also what kind of temperatures are you getting using Air cooling. I plan on using OCCT when I get home tonight to try and isolate what my problem areas are so I don't spend a week with these long test runs trying to figure it all out.
Your thoughts and or suggestions are greatly appreciated.
eVGA 680i P25 Bios
vNvidia 8800GTX
