stainremover
- Jul 19, 2008
i wanted to do a watercooled sff system with an 2x80mm radiator i'm looking to retire from my main rig. will this be enough cooling for a gtx275 and a cpu of some kind (most likely just a core2 duo)?
this is the radiator i'm using:
http://www.dangerden.com/store/black-ice-micro-ii.html#tabs
it is "Rated for 570 KCal per hour (2261.91 BTU per hour)"
