defuseme2k
- Oct 7, 2004
Just a quick question that I believe I already know the answer to, but let me elaborate below.
BTW I'm using ESX 3.5, so no fancy path awareness :<
Every LUN I care to worry about is visible to 10 ESX hosts, and 2 VCB proxies. I'm using FIXED pathing per HPs best practice (which I know is a heated debate, not to be had here). I then manually load balanced the ESX side and set the HP EVA not to failback (we monitor heavily). My VCB proxies are using MPIO and the HP DSM, using SQST (there are 4 active paths to everything).
Should I turn of SQST on the VCB proxies? Should I specify the active path to match my ESX hosts and then set the other paths as standby for redundancy sake only? The reason I ask is because if my understanding of ALUA is correct, regardless of what I have the LUN ownership set to via Command View, if an I/O request is received by the proxy controller, then the LUN ownership changes and can cause 'thrashing'. Maybe we haven't noticed is too much because it is at night that backups occur, but I could see with the ESX hosts being set fixed that it would be possible to have this happen while using VCB.
