Cousin Patty
- Jul 21, 2005
Which option in the BIOS tells it not to set its own volts for the cpu core? The actual value is usually about a little less than what I tell it to be at. So if I tell it to run at 1.40v, it will show that its at 1.35v for example. Thanks
