And the point of this was....that it does actually exist?
I'd personally just like to see the pics...I thought it was going to show it in action!
512Bit !
http://img.hexus.net/v2/internationalevents/cebit2008/TS/Monday/albaGX2-big.jpg
They're not just adding the two 256-bit buses together and proclaiming it 512-bit, are they...?
damn that thing is hugggggggeeeeeeeeeeeeee
I have the strong feeling they are since they added up the RAM.
they can add the ram up and be correct as there is actually 1024 mb of ram on the card, however, ten 256 bit memory buses running together still is a 256 bit
Nah, it's an optical illusion, those dudes are just really small.
No, not really. If you look at any of the recent cards they get their bus by running multiple smaller ones together. Hence the difference between the GTS and GTX. The GTS had 5 64-bit memory controllers, the GTX had 6. That gives 320 and 384-bit buses respectively.
Holy shish.... Everyone, check :15 into this video! Did someone steal H's upcoming 9800GX2 review? Look at the watermarks behind the first few pictures. This was listed as a related video when i watched the vid that the OP posted.
http://www.youtube.com/watch?v=Z7H9QSc31JA&feature=related
Well if you can fit 8800 GTX in your case then you can fit this one too. This will fit to ALL ATX-cases [yes I know that there are few cases that aren't ATX compliant, but marketing departments still call them ATX..Will this card have trouble fitting in some cases?.... looks like a monster.
