mathesar
- Jul 5, 2005
I have a Samsung 2333T LCD which can run 72hz refresh rate without skipping frames, the problem is if I run anything over 60hz my GTX 480's idle temp jumps from 50-52C to 80C even tho the GPU usage is at 0%, Is this a known issue or maybe something I'm overlooking?
At first I thought maybe it was because i'm running dual monitors and the combination of 60hz / 72hz was causing the issue, but the problem persists even if I disable the 2nd monitor.
As soon as I change the 2333T's refresh back to 60hz the GPU temp drops back to normal.
Any ideas appreciated.
