I was wondering if anyone knew where to get the thermal pads that are on the ramsinks as well as the voltage regulators the evga 8800gts. I'm using an after market cooler, but would like to get them just in case I need to replace it with the original. I ripped some of the thermal pads as I was removing the cooler.
Also I was wondering if it is safe to use AS epoxy on the voltage regulators as well as the IO chip. The heatsinks on them keep failing off. I would be using 50 % epoxy and 50% TIM.
Thanks
Thanks
