I'm trying to find a way to keep case exhaust temps cooler so i don't heat my room up, but without making my case noisy. As an example, I gave up on a GTX 480 with stock heat sink because for me, that is way too noisy while playing games.
Skip to the bottom paragraph if you want to avoid reading about MY specific case & components currently.
I currently have a Lian Li PC-7F type case with Noctua fans. I did remove the internal HDD cage to hopefully get better airflow from the front. If you're not familiar, its a 140mm intake in the bottom front and a 120mm exhaust in the back by the cpu. The PSU is on the bottom and supposedly intakes from the bottom through slots, exhausting out the back. Components are an Intel 930 w/a Venomous X & Noctua fan. GPU is back down to an ATI 5870, but with the newer fan & heatsink that does not exhaust air. The case fans are at full power. There's also 1 optical drive and one SSD. No conventional HDDs in the case.
A few days ago, I was playing with a Zotac GTX 480 amp, which is quieter than stock, but also does not exhaust heat. In a very open area, I found the back part of the top of the case to be VERY hot to the touch. Probably about 125 degrees F. The back exhaust was equally hot. CPU was up at near 50 degrees C and GPU was at 70 C (per Everest Ultimate) while gaming. The hot air from my case definitely warmed the area. In contrast, my friend's AMD / 8800 GT system in an Antec 900 case had cool exhaust.
So, all of that to ask - is it possible to have enough cooling in a case (non-water cooled) that exhaust temps will not alter the overall room temperature of a small (12'x12') room? Because right now, the exhaust is HOT and the room temp goes up by an easy 10 degrees F while gaming.
