Battleneter2
- Nov 3, 2006
There is a lot of confusion surrounding safe Core 2 Duo temperatures concerning Tcase and Tjuction.
Lets start with this, when someone states ""my CPU temperature is 70C"" is this safe or not? Well it depends on what readings they are looking at.
I have used 4 common programs to display temperature
TAT
Coretemp
Easy Tune (gigabyte boards only, Asus etc have there own software)
Speedfan
Tjunction max (in red) max temp threshold is (85C). It is logical to assume Tjunction is fine at to say 75C (as long as Tcase is below 61.4C). This issue becomes a little more complicated as the gap between Tcase and Tjunction can varie on different machines depending on the type and quality of cooling.
Tcase max (in Yellow) is (61.4C). Intel clearly show in the following PDF 60C is safe for sustained periods of time. At 60C (Tcase), Tjunction is usually substantially higher.
For a more detailed description please refer to the following Intel official Specification PDF.
http://download.intel.com/design/processor/datashts/31327802.pdf
Add to all of this Tcase seems to be read/calculated a little differently on certain software.
Basically when stating a temperature you should state the software used. Also when giving advice to others concerning temperatures, Tjunction or Tcase needs to be determined first, 70C can be fine or it can be terrible. It is better to know both Tcase and Tjunction temperatures.
TAT
Coretemp
Speedfan
