I'm getting an Asus G1S-B2 Gaming laptop this weekend. I'm in the USAF and will be using it mainly for TDY's and deployments. I need an external harddrive to use to put my movies and music on and maybe for backup purposes. I'm looking for a capacity of around 200gig but can go higher. Budget is around $200. The G1s-B2 is USB/Firewire/eSATA so any of those are fine for connecting to the laptop. I do not care if it is an external that requires exteral power but no having to do so would be a plus. This leaves eSATA off though.
I have a WD My Book 500GB for my main PC now. I have thought about getting another such as this one.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136081
Should I?
I've also been looking at the WD 200GB Passport. http://www.newegg.com/Product/Product.aspx?Item=N82E16822136139
Any help and advice would be appreciated.
Laptop link for curious: http://www.newegg.com/Product/Product.aspx?Item=N82E16834220256
Should I?
