We're looking to move our mirrored arrays off of the database server into an external cd-tower.
Here's the one I'm considering:
http://servercase.com/miva/miva?/Me...uct_Code=CK7091&Category_Code=SCSI+Enclosures
It's a 9-bay, so getting our SCSI SCA drive planes (5 two-drive hardware mirrors) in there shouldn't pose any issue at all, but I'm more concerned about the external part of it. The irq's for the arrays that are in the server box now are fine, but if I use the external ports on the SCSI card in the box now, and route them to the external tower on seperate channels (like it is now), will things work out okay even though they would go through the 68-pin connectors on the back of that tower?
I know it shouldn't affect the mirrors (will backup beforehand), but I'm more worried about whether or not it would work at all if after the money would be spend on the case and two cables (roughly $250).
I'm actually not sure on upgrading the PSU. Could I just do the wire trick to use it without a motherboard, and have the on/off switch controlled by the switch on the PSU or the front, or what? Would 300w be enough for 10 drives to spin up on boot? nevermind that it's an unknown make and model PSU. I'm guesstimating a generous 30w for full-time operation of 10 drives, just need some other opinions.
Thoughts?
Thoughts?
