DarkenReaper57
- Oct 2, 2003
Hello everyone,
I have a Silverstone Zeus ST65ZF 650W PSU. It only has an 80mm fan for cooling, which can get to be quite loud. I actually replaced the stock 80mm fan with a Panaflo M1A, but this fan is still the loudest in my system.
I was thinking of modding the PSU and install an externally-mounted 120mm fan on the top. While an internal solution would be ideal, it simply wouldn't fit, as can be seen here: http://insanetek.com/content/view/223/27/1/3/. The aluminum heatsinks are just too tall.
Has anyone ever done this? The idea is to reduce noise and not spend a ton of money on a new PSU. If anyone can recommend a good replacement for this PSU at under $120, I might be up for that. This PSU is rather old as SLI-certified units go, and the number of amps on each of the 4 rails isn't ideal.
