I have a Modded Shuttle SB75S for sale. This is the Soldem Pearl white designed case.
The mods are blow hole on top and cut out rear screen with dual fans for push pull on the Ice cooler. I use (3) Zalman OP80 fans. They are a little noisy but you can change them out or turn them down with SpeedFan.
Also modded the Northbridge heatsink to the Zalman fanless one.
The Shuttle motherboard has 1Gb NIC, (2) SATA connectors, IDE connectors, onboard sound, and 2 slots for DDR memory capable of up to (2) GB.
Installed is a Pentium 4 Northwood 3.0c. It has 512kb L2 cache and it's never been overclocked.
Also installed are (1) GB (2 x 512) Corsair XMS 3200C2 Platnum.
Finally, it has a Sapphire ATI Radeon 9800Pro with Iceberq heatsink/fan on the GPU.
This is a packaged deal for $500.
All you need for this to be complete is a SATA or IDE harddrive and a DVD-ROM, if you want.
Reply to this thread or Private Message me. My ebay ID is domlam28.
A review of the box here:
http://www.extremetech.com/article2/0,1558,1584451,00.asp
A pic with the cover off.
