i guess since one of the IHS's functions is to distribute the core's heat output over a wider area, it wouldn't be a bad idea to cover the whole surface with a very thin layer of as5.clone#13 said:Hi all, I noticed that the new AMD 64 chips have a one piece face plate cover over the dye core. My question is: Do you apply artic silver to cover the whole face plate? I am planning on using the Zalman CNPS7700-Cu cpu fan.
MetalStorm said:I disagree.
On an Intel P4 or Athlon64 type CPU with a large metal heat spreader, put a small amount of Arctic Silver onto the center of the heat spreader as shown in the photo.
Only a small amount of Arctic Silver is needed
P4- About the size of an uncooked grain of short-grain white rice or 1/2 of a BB.
Athlon64- About the size of one and a half uncooked grains of short-grain white rice or 3/4 of a BB.
RECHECK to make sure no foreign contaminants are present on either the bottom of the heatsink or the top of the CPU core. Mount the heatsink on the CPU per the heatsink's instructions. Be sure to lower the heatsink straight down onto the CPU.
Once the heatsink is properly mounted, grasp the heatsink and very gently twist it slightly clockwise and counterclockwise one time each if possible. (Just one or two degrees or so.)
Please note that some heatsinks cannot be twisted once mounted.
Our testing has shown that this method minimizes the possibility of air bubbles and voids in the thermal interface between the heat spreader and the heatsink. Since the vast majority of the heat from the core travels directly through the heat spreader, it is more important to have a good interface directly above the actual CPU core than it is to have the heat spreader covered with compound from corner to corner.
