Starting to put together some of the pieces of my new build and I had some concerns and questions regarding fans and fan controllers.
I'll probably be using the Aerocool Touch 2000 because it's the best touch controller out there right now. The only thing kind of shitty is it's 6w max per channel. I wanted to hook up 3x Yate Loon D14SM-12 and was trying to figure out a way to do it. Pretty much the only way I can think of it take some wire and make my own harnesses. Over at FrozenCpu I can get black/yellow/red wire by the foot but they sell both 18AWG and 22AWG and I wanted to know which I should use? I was thinking of using the 18AWG which would be the thickest and therefore most durable but wanted to know if it was electrically sound with the wattage limit for the fan controller (I don't know shit about electrical engineering). Do I need to solder them or can i just strip them and twist the pairs? If I need to solder, please point me to a kit that can do what I need of it.
If I were to do it and sleeve it all how would i do it? this work? http://img514.imageshack.us/img514/6315/57196614.jpg
Also, I was going to sleeve the stuff with MDCP-X and was wondering if the red/yellow would show through? I kind of wanted to use the red and yellow because that's the fucking color that shit is supposed to be (freaking OCD) but if it's going to show through, I can do it all black wiring.
Since there are 4 channels, and I was gonna use a Mountain Mods Pinnacle 24 CYO which will soon have 140mm rad support. I was gonna do:
1) Pump
2) PA140.3 with 3x Yate Loons for Processor/MB
3) PA140.2 with 2x Yate Loons for Video card (maybe not, depends on prices of waterblocks for 6800 series)
4) 1x Yate Loon for intake, 2x for exhuast (I would do 1, but since there are 2 exhaust ports, might as well put two in there
any thoughts?
TL;DR
1) Any better fan controllers than Aerocool Touch 2000 or ways to increase max wattage (bigger heatsinks?)?
2) RE custom wire harness: 18AWG or 22AWG
3) RE custom wire harness: Solder or twisting?
4) Can you see red or yellow through MDCP-X?
5) Any other nice 140mm fans coming out anytime soon?
thanks in advance guys
EDIT: Also, not really relating to cooling, but if I wanted to extend the case's power switch/front panel stuff for cable managment, 18AWG???
1) Pump
any thoughts?
TL;DR
