Would the G. Skill SSD work in a standard laptop (X61S - uses a 2.5" drive)?
I believe most netbooks use mini PCI-E for the SSD interface.. so you got to check to see if what you buy will work in your system.
http://www.electricvagabond.com/2008/10/super-talent-gives-your-netbook-ssd.html
Edit: Crucial has a page dedicated to helping with this.. (sells their product, but from that you can figure out what you need) http://www.crucial.com/netbook/index.aspx
The acer aspire one hard drive version has sata and uses a normal laptop hdd so a 2.5" ssd will work with it.
