I recently purchased the parts for a new rig. i7-3770K, 32GB RAM, 2x680 superclocked, 2xRAID-0 SSD sets. I'm hoping the system be smokin'!
Problem is, I haven't bought a monitor. At first, I was going to go with the BenQ XL2420TX, but then kept seeing NCX's reviews and all the bad reports of its nVision 2 transmitter issues, and something about it's antiglare coating being a problem. Also saw that at 60Hz, the input lag suffered. Oh and problems with ghosting. So I got turned off quick.
I want a monitor to use for programming and gaming. I'd like to connect my PS3 to it, but most importantly, I want to use the two 680s in the machine as optimally as possible.
So my question:
Get a 2560x1440p monitor (which I hear suffers from input lag because of the scalers) and also is limited to 60fps because of the 60Hz ceiling
OR
Get a 1080p set that has low input lag, 120Hz, and good picture quality. (Contenders are unfortunately the ASUS lineup - I say unfortunately, because I've bought those before and have been bit by backlight bleed issues).
OR
Wait for the new Asus 144Hz 1ms response time monitor to come out (hopefully this month). That's only 1080p though.
What do you suggest, [H]? Which monitors feed my need and should be looked at before I shell out my hard earned cash to some dealer? I could use some suggestions/advice/blistering-hot-insults ASAP. Many thanks ahead. OH and I should mention, I'm not really interested in buying from Korean eBay sellers. Don't want to gamble on that. Would prefer US dealers who I can deal with good customer support if I have a problem with the display.
So my question:
OR
OR
