I was considering get a Blu-Ray reader (Lite-on) at Newegg for about $200. My monitor is a 22' 1680x1050 resolution. I'm aware that this would be downscaled to 720p while watching any DVDs or Blu-Ray discs.
1.) Will 720p Blu-Ray still be worth it (in terms of visual quality) than 720p DVD, or do you have to run in 1080p to take full advantage of high-def?
2.) Both my monitor and GPU are HDCP compatible, but is there a special connector to use? I'll be using DVI, but I wasn't sure if there was something else that would be needed in terms of the connection.
Sorry for my lack of knowledge on the subject and thanks for taking the time to help
