I'm not an overclocker, but I expect to OC the CPU to 3.0~3.1 Ghz, that's why I didn't go for the 1066mhz RAM.
I'm gonna do some online gaming so the wifi card should be good.
CPU: Intel Q6600
Motherboard: Asus P5Q pro (Any better MB at that price?) http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299
Memory: XMS2 DHX 2x2gb http://www.newegg.com/Product/Product.aspx?Item=N82E16820145194
VGA: Asus EAH4850/HTDI/512M http://www.newegg.com/Product/Product.aspx?Item=N82E16814121253
Monitor: Acer AL2216Wbd http://www.newegg.com/Product/Product.aspx?Item=N82E16824009094
HDD: Samsung HD642JJ 640Gb 7200 RPM http://www.newegg.com/Product/Product.aspx?Item=N82E16822152134
DVD: Samsung SH-S223Q/BEBN http://www.newegg.com/Product/Product.aspx?Item=N82E16827151173
Wifi card: Linksys or DLINK
http://www.newegg.com/Product/Product.aspx?Item=N82E16833124115
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16833127080
Case and power supply: I'm still confused a bit:
RAIDMAX case + PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16811156062
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146025 and
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341002
Do you think the power supply of the RAIDMAX case should be enough for the system? Remember that I'm not going to overclock it to the max, just some basic CPU OC to 3.0Ghz
CPU: Intel Q6600
or
or
