FallenMystic
- Jan 20, 2006
Greetings all,
I decided to start playing with water recently, (low end TT system with a few additions/subtractions,) and before I got to far I figured I'd head here to make sure I've got the initial setup right before I go too nuts... let me know if this looks OK or if I've fot thigs rolling in the wrong direction.
Thanks!
This is a 'custom' fill port I decided to try out, didn't want to go with the standard bay res because well I'm using the bays up with HDD's, (it's intended to be a server of sorts,) I just haven't figured out what yet.
First pass on a paint job for the Rad and the waterblock, (hated the look/design of the TT waterblock so I went with this Koolance block,) it's going to go on an Athlon64 chip. Eventually the case/water setup is going into a mod; the water system was actually intended for another build but it's taking me longer to get the other build off the ground.
These are a couple of shots of the whole loop, currently only the CPU in the loop, I was going to include the chipset as well but the DIY block I picked up cracked so that got left out of the mix.
This is a shot of the pump and the 'T' setup I'm using, (its actually a Koolance drainport,) but it seems to work thus far for what I'm using it for.
Thanks for any input.
Thanks!
