AnNiMosSiTY
- Jan 1, 2001
Hello, Ive been wanting to upgrade my PC and I figured I would give OCing a try to get a little more out of my system since its free.
I have a
Gigabyte GA-965P-DS3 Mobo with a dual core E6400
Zalman CPU Cooler ( cant remember model but it was best at time of purchase)
4 GB Ram
8800 GTX
520 Coolmax PSU
System is a couple years old, I built it the first week WoW: Burning Crusade was released.
I tried OCing my first time a couple days ago, after much reading it seemed pretty simple to go for a mild overclock.
I went into the BIOS and the GB mobo has the tweak M.I.T feature to edit your FSB, Vcore etc...
I tried some popular settings with this setup. I tried the following
2.40GHz: 300mhz FSB, DDR2-800mhz, no CPU voltage increase.
· 2.56GHz: 320mhz FSB, DDR2-800mhz, no CPU voltage increase.
· 2.80GHz: 350mhz FSB, DDR2-800mhz, .1v CPU voltage increase.
The 2.80 made it for about 5 minutes and my pc would crash. I tried 2.56 and it made it a little while longer but would crash when I would close programs. I then tried 2.40 and had the mobo set the voltage to auto which was default.
After that my PC would not boot, when I press the power button all the fans and lights start then they all stop 5 seconds later then start again. It will just keep repeating this over and over. I thought my PSU was just fucked since I have seen PC's do the same thing as this and it was just a bad PSU.
I hooked my PSU to my brothers system and it worked just fine so its not the PSU. I unhooked all my componenets 1 by 1 in case that was it and I had the same results. Is there anything else I can try or am I pretty much fucked and something on my Mobo got toasted?
This is my motherboard I'm using
http://www.nordichardware.com/Reviews/?page=1&skrivelse=502
I have a
4 GB Ram
8800 GTX
520 Coolmax PSU
