Still missing some parts on my project, so I went and measured the flowrates to at least get something going. I first installed a Dwyer RMC flowmeter inline to get accurate direct readout. Connections were made with 1 ft 1/2" ID tygon tubing, the pump was imersed in a large reservoir to eliminate an yhinderance on the suction side.
Flowrate with just the RMC: 3 gpm
added TDX block:2 gpm
added Maze4 block: 1.75 gpm
added 77 Boneville heatercore: 1.5 gpm
Now, the Eheim 1250 is supposed to deliver 5 gpm, quite obviously the flow meter is strongly restricting the flow. I therefor repeated the series without the flowmeter by measuring the time it took to fill a 1 gal container.
Just the pump: 12 sec = 5 gpm
added TDX block: 29 sec = 2.1 gpm
added Maze4 block: 34 sec = 1.8 gpm
added heatercore: 38 sec = 1.6 gpm
repeatability was +- 1 sec
I also measured the other two components singly
Maze4 block: 22 sec = 2.7 gpm
Heatercore: 23 sec = 2.6 gpm
Quite obviously the Eheim 1250, despite being rated a rather substantial 300 gph pump, does not have the power to drive water through a TDX block at the reported 3 gpm max flowrate. Adding the GPU block and radiator inline has comparitively minor effects on the overall flow in this configuration, as has the flowmeter.
Surprisingly the flowmeter does add a lot of noise to the system, so I will not make it part of the final design.
I will add data on different parallel designs later.
