mathesar
- Jul 5, 2005
lockheed2266 said:Is anyone seeing any perforamce boost with an Dual Core CPU from the 81.87 Drivers?
Riptide_NVN said:I assume he means higher resolutions, where the GPU will be the bottleneck in most situations. CPUs are mainly a factor in 1280x1024 or less.
Viper87227 said:What are you talking about? With the current high end GPU's.... all CPU's are a bottleneck.
J-Mag said:Exactly opposite of what you say is the truth. I don't know where you guys get this idea that you need extremely fast CPU's to run high end GPUs... Modern games stress the Graphic sub-system FAR MORE than anything else.
http://www.firingsquad.com/hardware/fear_cpu_performance/page5.asp
http://www.firingsquad.com/hardware/quake_4_cpu_performance/page9.asp
I can't find it right now but there was nother that showd BF2 even at 1024x768 is not CPU limited.
There is barely any difference between the CPU's when you run games at whatever maximum resolution your card can handle.
Viper87227 said:Yeah... that came out wrong. I know that CPU's these days don't affect gaming much. I have seen those firingsquad benchies before... as well as others. I believe ive seen the BF2 bench you speak of. Not sure what I was thinking TBH, but that post didn't really reflect it.
Sonicks said:What does it mean when I get the same FPS (34 in one particular spot) with 2xAA and 4xAA in Quake 4 at 1280x1024? Also, I dropped the resolution down to 1024x768 and in that same spot with 4xAA i got 30fps. Whats the deal here?
Well I say this becuase a lot of times I feel as if I could be getting more out of my GTX. The frames I'm getting match those found here but I run it at 1280x1024 and no AA.mdameron said:Did you driver clean in between? Just use what works best
Mojo3k70 said:These drivers have finally made my CoD2 playable at decent settings! Before I would need to run 800x600 on med for playable framerate, now I run a constant framerate of 35-45 (rarely ever drops below that) at 1024x768 / high.
I run a 6800gt for the record.
Jodiuh said:What dri set did you use before?
GoldenTiger said:Compared to the 78.05 beta's I was on for awhile, this set seems to be a lot nicer performance-wise in my games. I haven't run 3dfark to test at all or any other benches yet, but seems better overall looking at the framerate counter as I play. I have a dual-core Athlon 64 X2 3800+ overclocked to 2.4ghz/core now.
