someone asked me about this board previously. i just finished putting together the rig which contains it and i must say that i am happy with the outcome. i overclocked the 140 i put in it to 1.8 with the most ease i have ever come across. the system so far is stable and folding. as far as the mobo goes, it comes with an array of cables, a very well written handbook, a sheet for mobo layout, and an sli bridge. it does require REGISTERED ram, but it doesnt have to be dual channel. the processor, and memory brand i used were NOT in the handbook as being certified to work with the board, but they do.
SPECS::
Ever Case GC4292R Black/ Red Steel ATX Mid Tower Computer Case++Modified A Bit++
ENERMAX Air Master UC-8ABS-B 80mm 2 Ball Cooling Fan++Rear Case Fan++
Foxconn NFPIK8AA-8EKRS Socket 940 NVIDIA nForce Pro 2200 ATX AMD Motherboard
PNY VCG68128XWB Geforce 6800 128MB GDDR3 PCI Express x16 Video Card
Antec SmartPower 2.0 SP-500 ATX12V 500W Power Supply
CORSAIR 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200) ECC Registered System Memory Model CM72SD1024RLP-3200
Western Digital Caviar SE WD800JD 80GB 7200 RPM Serial ATA150 Hard Drive
LITE-ON Black IDE CD Burner Model SOHR-5239V BK
OCZ H-OCZBGACRS8 Copper BGA Ramsink 8 Pack++For Vid Card++
ARCTIC COOLING ARCTIC FAN 3 80mm Cooling Fan++Top Of Case++
ARCTIC COOLING FREEZER64 ACFZ64 80mm Ceramic Cooling Fan/Heatsink
the Bios allows for some decent control in the overclocking department. this aint no dfi lanparty, but it does let you tweak the system.
SPECS::
