First of all, the specs (from what I can remember)
MSI K8T Neo mobo
AMD Athlon 64 bit 3200+ processor
1gb of RAM (2x 512mb)
120gb SATA HD (old)
200gb SATA (just installed)
ATI Sapphire 9200 video card
He got it yesterday (after being in the hospital for a few months, then he got a room in my house), and his friend said that when he turned it on, he saw smoke and the HD was getting hot. So I did some research, checked the video card (it worked in my computer, except that it didn't support the resolution I had), but I didn't check the HD, because it was a different interface than mine.
I recommended to get another HD and I just installed it tonight.
After all that, it didn't want to boot up, POST, or nothing; the monitor's standby mode kicked in a few seconds after, and I already checked it on another computer. The lights, fans, processor, they all work, so I assume that the PSU is good.
Should I swamp my PSU with his to see if that's the problem? Nothing seems burnt, melted or damaged though.
MSI K8T Neo mobo
120gb SATA HD (old)
