Have to get rid of some gear, no more space left in the house!
Pentium 3 server bundle consists of:
Tyan Thunder LE-T (S2518UGN) Motherboard featuring:
Dual Pentium 3 1Ghz Socket 370 CPUs
Dual Alpha heatsinks with 60mm fans (NOTE: These are standard height and can not be used in a 1u case). The fans have had the power and ground wires detached from the motherboard connector in order to run them at 7v for nearly silent operation.
4 512MB ECC PC133 DIMMS; Cant recall manufacturers off hand (I believe 1 set is Crucial and 1 set is Kingston); 2 sets of 512MB DIMM pairs, each pair has a different manufacturer. RAM never failed and passed memtest for 72 hours before the server was decommissioned.
Samsung 220WM Monitor - SOLD
Received this as a present for Christmas but only used it for a day and put it back in the box. Comes with power and DVI cables. Monitor is great, no stuck pixels, very clean looking. I bought a 37 TV the day after I received this and have been using that as my monitor since.
Features include:
Prices:
Server Bundle: $95 + Shipping
Monitor: SOLD
I am located in 60660 if you want to run shipping estimates; references in my signature!
- Dual PGA370 ZIF sockets
- Integrated Adaptec AIC-7899W Dual-Channel U160 SCSI controller
- One 64-bit 66MHz (3.3-volt) PCI slot and one 64-bit 66MHz (5-volt) PCI slot.
- Integrated Dual Intel 82559 LAN 10/100 controllers
- Supports up to two Intel Pentium III Processors or Pentium III Processors with 512kB Cache (Including Tualatin Processors)
- 4 angled PC100/133 ECC DIMM slots; 4GB max- Integrated Adaptec AIC-7899W Dual-Channel U160 SCSI controller
Features include:
- Screen Size : 22''
- Resolution : 1680 x 1050
- Brightness : 300 cd/m²
- Contrast Ratio : 700:1
- 5ms Reponse Time
- Built in speakers (5w total I believe; loud enough to watch movies through if you so desire)
- 5ms Reponse Time
Prices:
Monitor: SOLD
