First up are the Samsung 220wm's NEW IN BOXES. NEVER OPENED.
EDIT, ALL SOLD.
pics:
Specs:
Monitor Type: Flat-panel LCD
Screen Size: 22"
Maximum Resolution: 1680 x 1050
Aspect Ratio: 16:10
Response Time: 5 ms
Brightness: 300 cd/m2
Portrait and/or Landscape Viewable: Landscape
Contrast Ratio: 1000:1
Flat Display: Yes
TV Tuner: No
Inputs: DVI-D D-sub
Compatibility: PC and Mac
Antiglare Coating: Yes
On-Screen Image Controls: Yes
Speakers : Yes, built-in
Energy Star: Yes
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001240
next up is my LG L204WT-SF 20.5" widescreen
This lcd seems to have some trouble with the dvi port and my vid card. I've looked into it and it seems to be a problem with a lot of lg monitors, so i've been using its vga. Looks great and works fine. If you know about EDID data and stuff you can probably fix it.
SOLD
Pics:
Specs:
Flat-panel LCD
2000:1 contrast ratio
300cd/m2 brightness
1680 x 1050 resolution
5-millisecond response
comes with dvi/vga cables and power cord
Email: [email protected]
Heat: http://www.heatware.com/eval.php?id=20396
ebay feedback: http://feedback.ebay.com/ws/eB...dback
EDIT, ALL SOLD.
pics:
Specs:
Screen Size: 22"
Aspect Ratio: 16:10
Response Time: 5 ms
Flat Display: Yes
TV Tuner: No
Inputs: DVI-D D-sub
Energy Star: Yes
SOLD
Pics:
Specs:
Flat-panel LCD
300cd/m2 brightness
