Time to clean up around here, so my precious tech gear is up for grabs once again!
heat: Blahman (6-0-0)
- Can take pictures if requested.
- Interested in all reasonable offers, fire away
- Intel Core 2 Duo E6750 SLA9V (G0) 2.66GHz 4MB L2 Cache 1333MHz FSB LGA 775:
Will overclock easily to 3.2GHz and beyond. Comes with original box, HSF, sticker, papers, and CPU tray. Upgraded to a Q9550 so this great little CPU is looking for a good new owner.
SOLD
- BFG 8800 GTS OC 512MB:
Very capable DirectX 10 card, probably the best of the first G92 generation, and still very powerful today. In like new condition and runs perfectly -- cool and quiet thanks to the dual slot reference cooler which exhausts heat out the back of your case instead of recirculating hot air. Comes with original box, accessories, and driver CD. Requires only one 6-pin PCI-Express power connector, and comes with the adapter to convert 2 molex connectors to 1 6-pin connector if your power supply doesn't have one.
PCI-Express 2.0, 512MB GDDR3
Core clock: 675MHz (vs. 650MHz standard)
Shader clock: 1674MHz (vs. 1625MHz standard)
Memory date rate: 1940MHz
Memory interface: 256-bit
Stream processors: 128
Shader Model: 4.0
HDCP Capable
Connectors: 2 Dual-Link DVI-I, HDTV + TV Out
Accessories: (2) DVI to VGA adapters, (1) HDTV component video dongle, (1) Dual 4-pin Molex to 6-pin PCI-Express power adapter
SOLD
- Samsung F1 HD753LJ 750GB 7200RPM 32MB cache SATA HDD:
VERY fast and quiet. No room for it in my Shuttle anymore, so my loss is your gain. Bare drive/OEM.
SOLD
- NETGEAR ProSafe FS108NA 10/100 Mbps 8-port all-aluminum Network Switch:
Very sturdy and cool aluminum chassis. Wall-mountable. Auto-crossover sensing. Comes with original box and accessories.
$15 shipped.
