Hello all. For sale is a 4.1 amplified computer speaker, in a perfect working order.
It is a Cambridge Soundworks FPS2000 Digital 4.1 Surround system with the following specs:
● Satellite power output: 7 watts RMS at 10% THD per channel
● Satellite dimensions: 3.5" x 3.5" x 3.5" with 2.5" long throw driver
● Subwoofer power output: 25 watts RMS at 10% THD
● Subwoofer dimensions: 14.1" x 8.0" x 6.5" with 5.25" woofer
● Frequency range: 50Hz - 20kHz
A review from Anandtech made the following points about these speakers:
● Crisp & Clean reproduction of high and mid frequencies
● Punchy deep lows
● Realistic 3D sound
Included in a package are:
● Four satelites and a subwoofer
● Four short stands for each satelite to be put on a desk
● Two tripods for the rear satelites to be installed behind you
● Power supply
● Volume control module that also adjusts front-rear balance
● Analong dual input wire to connect the built-in amplifier to your soundcard's front and rear outputs
● Digital cable and a computer bracket that connect the speaker system to a Creative SoundBlaster card if you have one to get digital sound input, and four wires to connect each satelite to the amplifier.
This is a moderately heavy and bulky item. Asking price is $35 including shipping. (FYI, the shipping for the box containing everything listed above will be around $20 using USPS.) Money orders only.
My Heatware
My eBay
● Punchy deep lows
● Power supply
My Heatware
My eBay
