just trying to clear out my apartment, the piles of parts are starting to get in the way.
everything is $4 or less, plus shipping. i will not overcharge for shipping, no handling fees or anything stupid like that. you choose the carrier and service, if you have no preference, i will go with whatever's cheapest. my heat is under KerriAnn (41-0-0), and my ebay is under kerriann1981 (83-0-0).
$4 items:
-White EL wire has been cut and resoldered, but clean job. Comes with both a clear car cig lighter adapter, and a molex adapter, for use in car or pc. sound activated, but can be switched to normal too.
-Stock heatsink and fan from an athlon 2000+. 3 clip design, used it as a temporary solution for my athlon 2500, and it kept it well cooled.
-80mm fan with 2 uv leds and 2 white leds.
$3 items:
-Compaq Silent Cool fan- 90mm, pushes a crapload of air.
-Sunon 80mm fan model KD1208PTBX-6A specs: Ball Bearing, 50.6 cfm, 40 dBA, 3 pin 2 wire, 4.3 Watts.
-60mm (x 25mm) Elina fan model HDF6025L-12MB-1 two wire- untailed, but i can solder something on it- just let me know if you want 4 pin or 3 pin.
-pc speakers- sony desktop 2 piece model PCVA-SP2. grayish color. at one point, i cut the wires, but they have been rejoined securely and cleanly. came with my sony vaio pcv-rx450.
-2 piece "multi media" speakers- that's what it says on the backside. frequency response- 60-20000Hz. has treble, bass, and volume control.
$2 items:
-UV Lazer LEDs- set of 3 lazer leds enclosed in a small black plastic box. has a 4 pin molex connector.
-Gameport I/O connector from an Asus board (A7N8X).
-(2) I/O switch plates. like the ones that come with ccfls. on/off switches.
$4 items:
$3 items:
$2 items:
