HomerRulez
- Apr 17, 2005
Its used but in Good condition. Screen is perfect with no issues or dead pixels or anything for that matter. Its perfect. Body is in good condition. The only thing is the system though that wont function is the battery. It powers on when plugged in to a charger (targus which isnt included) and can be used with no problems when plugged in. It just doesnt work with the battery. All you need is a new battery and your good to go. Aside from that battery, this is a perfectly working machine. It comes with laptop only. No ac adapter and while battery is included, it doesnt work. The laptop itself works flawlessly however and can eb used to game on at 1,280x800 or high if you use the vga or hdmi ouput it has. Here are the specs for the core 2 duo notebook
Im looking for $250 on this system.
HP Pavilion dv2700t Special Edition Laptop specifications
- General
- Width 9.3 in
- Depth 13.2 in
- Height 1.5 in
- Weight 5.3 lbs
- Notebook type Thin-and-light (4-6 lbs.)
- Processor
- Processor Intel Core 2 Duo T5450 / 1.67 GHz
- Data Bus Speed 667.0 MHz
- Cache Memory
- Type L2 cache
- Cache size 2.0 MB
- RAM
- Installed Size 2.0 GB / 4.0 GB (max)
- Technology DDR II SDRAM
- Storage Controller
- Storage controller type Serial ATA
- Storage
- Floppy Drive None
- Hard Drive 120.0 GB
- Storage Removable None
- Hard drive type Standard
- Optical Storage
- Type DVD+/-RW
- CD / DVD read speed 24x (CD) / 8x (DVD)
- CD / DVD write speed 24x (CD) / 8x (DVD)
- Display
- Display Type 14.1 in TFT active matrix
- Max Resolution 1280 x 800
- Features High-Definition BrightView Widescreen
- Video
- Graphics Processor / Vendor Nvidia Gefore 8400M GS
- Audio
- Audio output type Sound card
- Audio Input Microphone
- Input Device(s)
- Input device type Keyboard , Touchpad
- Telecom
- Modem Fax / modem
- Max transfer rate 56.0 Kbps
- Expansion / Connectivity
- Expansion Slots Total (Free) 1.0 ExpressCard 54/34 , 1.0 Memory , 1.0 PCI , 2.0 Memory card reader
- Interfaces 1.0 x USB 2.0 - RJ-11 , 1.0 x S-Video - VGA , 2.0 x Consumer IR - USB 2.0 , 1.0 x Modem - RJ-45 , 1.0 x IEEE 1394 (FireWire) , 1.0 x Display / video , 1.0 x Microphone , 1.0 x Expansion , 1.0 x Ethernet
- Miscellaneous
- Features HP Imprint Finish , Intel PRO/Wireless 3945ABG Wireless LAN , Camera
