Contact
First off, thanks for looking at the thread. Please bump the thread if your look and I will return the favor. I am mostly easily reached in this order:
email: ryan [ at ] ryanlanhamonline.com
aim: ryanalanham
pm
Email is the quickest way as it goes directly to my blackberry.
Payment
Paypal is of course the easiest and safest way to pay. I will however take money orders, personal check (item will not ship in till check clears), or if you would like to work some other form of payment I am very flexible.
Shipping
Everything is shipped ground via UPS. Packages are shipped during my lunch break at work. All packages will be shipped out of Chicago. All prices include shipping in the US. All other locations will be actual cost.
Creds
You can look up my heatware under RLO.
Items
Trades / OBO
None of the above prices are set in stone and I am flexiable. Just please don't waste mine or your time with lowball offers.
Trades, i'm not really "looking" for anything but I am always intreated in high end PC parts or electronics.
Thanks For Looking!
aim: ryanalanham
pm
Payment
Shipping
Creds
Items
Nikon D100 SLR Camera + Extras
This SLR works great however, its time for me to upgrade to the D200. There is minor discoloration in the red rubber grip from use, and a few minor scruffs on the body. This camera is in 100% operational condition.
This is not only for the camera body but also for:
Nikkor AF-S 24-85mm Lens - ( Brand new. Only 3 months old.)
1:3.5-4.5G
Nikkor AF 28-200mm Lens]
1:3.5-5.6D
Speedlight SB-50DX
Sandisk 128MB Compact Flash
Lexar Pro 1 Gig Compact Flash
Quantarry carrying bag
Battery Charger
Rechargeable batteries X 2
Asking: $655 Shipped, Was $735
SOLD
SOLD
1:3.5-4.5G
1:3.5-5.6D
Speedlight SB-50DX
Battery Charger
Cisco 501E PIX
Works great. Was pulled form a working network setup. I have replaced this a Sonicwall. End user will need to connect to this device and reset it to factory default.
SOLD
BlackBox KVM
Provides 1 Local User and 4 Target Machines. Comes with 2 cables. This was used when I use to run a lan party.It let me easily control multiple computers. No longer needed but works great. This has a build in OSD and hotkey functions.
SOLD
BlackBox 16 Port Switch
Same reason as above works great, but no longer need it. This is a high performance switch.
Features
Auto MDI-X function on all ports eliminates the need for cross-pinned cables.
Non-blocking, store-and-forward switching architecture.
Full wire speed.
The Pure Networking family of Ethernet components from Black Box makes it easy for you to build a small 10-/100-Mbps Ethernet network. Pure Networking components are affordable, go together easily, and work with any standard Ethernet components you may already own.
Our 10/100 Ethernet Switches are the traffic managers of your network. They examine each data packet and send it to the correct port.
The switches are smart and easy to set upsimply plug in your devices. Theyre self learning and determine the Ethernet addresses in use on each segment, building a table as packets are passed through the switch.
Specifications
Buffer LB8505A-R2: 128 KB;
LB8508A: 256 KB;
LB8516A: 512 KB
Filtering and Forwarding Rate 148,800 pps
MAC Address Table LB8505A-R2: 1K;
LB8508A, LB8516A: 8K
Standards IEEE 802.3 10BASE-T, IEEE 802.3u 100BASE-TX
Switching Architecture Store and forward
CE Approval Yes
Connectors LB8505A-R2: (5) RJ-45;
LB8508A: (8) RJ-45;
LB8516A: (16) RJ-45
Indicators LEDs: Per unit: (1) Power;
Per port: (1) 10/100 Mbps; (1) LNK/ACT
Power 120 VAC, 60 Hz, external power supply
Size LB8505A-R2: 1.3H x 5W x 3.3D (3.3 x 12.7 x 8.4 cm);
LB8508A: 1.4H x 7.4W x 3.9D (3.6 x 18.8 x 9.9 cm);
LB8516A: 1.4H x 11.4W x 3.9D (3.6 x 29 x 9.9 cm)
Weight LB8505A-R2: 0.4 lb. (0.2 kg);
LB8508A: 0.6 lb. (0.3 kg);
LB8516A: 1.1 lb. (0.5 kg)
Asking: $40 Shipped
Features
Full wire speed.
Specifications
LB8508A: 256 KB;
LB8516A: 512 KB
CE Approval Yes
LB8508A: (8) RJ-45;
LB8516A: (16) RJ-45
Asking: $40 Shipped
Trades / OBO
Thanks For Looking!
