Most of the stuff you would need for a decent gaming rig for sale, $490 shipped to lower 48.
Heat: http://www.heatware.com/eval.php?id=15727
Selling gaming rig, as I have upgraded. I would like to mention I am not a big gamer, and have not run this rig much. I would say the rig is lighly used and can provide plenty of gaming enjoyment to its next owner.
I have not listed the case (stacker) or hard drive, and just to be clear, are not part of the deal. These parts are out of date, and case is heavy (shipping), and one could easily do better for the money, however if you are interested in these let me know and we can deal.
SeaSonic S12-600 600W Power Supply
http://www.newegg.com/product/product.aspx?item=N82E16817151025
Comes with original packaging, and documentation.
Gigabyte GA-P35-DS3R (rev. 1.0) Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128050
Comes with original packaging, owners manual, driver disk, io shield, stata cables, and floppy IDE cable.
Intel E8400 CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
This CPU is running at 4 GHz on stock vCore, (see photo below), and has performed flawlessly. Never blue screened, or produced errors. It is very easy to OC. Under load the CPU has run in the 55 deg C range on the water cooling system shown below, however as I said it is seldom used, much less at full load. I would guess it has plenty of life left.
Comes with original packaging, documentation and heatsink.
D-TEK FuZion v1 Universal CPU Waterblock - 1/2" fittings CPU Water Block
http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=182
Comes with original packaging, documentation, AMD rentention plate, bolts, nuts
Crucial Ballistix 2GB PC2 8500 Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148069
EVGA 8800 GTX Graphics Card
http://www.newegg.com/Product/Product.asp?Item=N82E16814130072
SAMSUNG DVD±R E-IDE/ATAPI Model SH-S182D/BEBE
http://www.newegg.com/Product/Product.asp?Item=N82E16827151133
Swiftech MCP655 Water Pump
http://www.newegg.com/Product/Product.aspx?Item=N82E16835108082
Comes with original documentation, neoprene pad, and mounting hardware.
Swiftech MCR320-QP Radiator
http://www.newegg.com/Product/Product.aspx?Item=N82E16835108098
