i am looking for 600.00 obo within reason. will only accept, for 625 with shipping included WITHIN THE USA.
[SIZE=+3]BRAND NEW - Infocus IN72 DLP Projector - HDMI Input![/SIZE]
[SIZE=+3]HDTV COMPATABLE - (720p, 1080i, 1080p/60, 1080p/24, 1080p/30, 1080p/50, 1035i, 575p, 576i, 576p)[/SIZE]
[SIZE=+3]Perfect for your Home Theater or for any other use![/SIZE]
The InFocus IN72 DLP™ home entertainment projector offers all of the excitement of attending your first rock concert! You can’t always get what you want? With the IN72, you can always get it – in sports, gaming or television entertainment. It’s like going out on the town without having to leave home! With its stylish design, it delivers more performance than a plasma TV – at less cost. Go for it! Live large. Invite your guests to see the latest movies in your own screening room. The IN72 truly brings it all back home.
You Have an Image to Uphold:
The powerful appeal of the IN72 goes far beyond the magnificent picture it projects onscreen. Its sleek, futuristic, low-profile appearance adds a subtle sophistication and mysterious magnetism to any room. The IN72 also clearly displays your discriminating taste in both home-entertainment technology and fine design.
Roll the Credits:
The IN72 uses Pixelworks™ DNX™ video-processing technology to dramatically improve the quality of video by combining multiple enhancement techniques to deliver clear, natural-looking standard and high definition images.
The Perfect Match:
The InFocus IN72 brings a big theater experience to home viewers everywhere. More portable and more versatile than a plasma TV, the IN72 is the perfect match for DVD players and gaming consoles. It’s a big performance item without the big ticket.
[SIZE=+3]Specifications:[/SIZE]
[SIZE=+3]Display:[/SIZE]Native Aspect Ratio:16x9Supported Aspect Ratio:4:3, 16:9Brightness:
(Represented as Max Lumens)Whisper: 720 Lumens
High Bright: 900 LumensContrast Ratio:2000 : 1 Full On/Full OffDisplay Technology:0.55" DarkChip2 480p 12° DDR, DLP by Texas InstrumentsData Compatibility:640 x 480, 800 x 600, 1024 x 768Video Compatibility:Full NTSC, PAL, SECAM, 480i, 480p, 576i, 576p, 720p, 1035i, 1080i, 1080p/24, 1080p/30, 1080p/50, 1080p/60Color Wheel (DLP Only):6 segment, 4-speed, D65 (6500K) color calibrationNative Resolution:854x480Projector Placement:Ceiling Projection, Front Projection, Rear ProjectionSMPTE Brightness:up to 11.5' (3.5m) wide on a 1.0 gain screenLamp Wattage:Whisper: 160 Watts
High Bright: 200 WattsLamp Life:Whisper: 3000 Hours
High Bright: 3000 Hours
Standard Lens Zoom:1.2 : 1Standard Lens Throw Ratio:1.76:1 - 2.12:1 (Distance/Width)Standard Lens Image Offset Ratio:128%Standard Lens Projection Distance:5 - 20 ftDigital Keystone Correction (Vertical):+/- 20°Digital Keystone Correction (Horizontal):Not AvailableMotorized Lens Shift:No
[SIZE=+3]Inputs[/SIZE] [SIZE=+3]and[/SIZE] [SIZE=+3]Outputs:[/SIZE]DVI:Number of Inputs: 1
Requires M1 to DVI cableM1:Number of Inputs: 1
Accepts VGA and DVI with M1 cable.HDMI:Number of Inputs: 1BNC:Not AvailableComponent (RCA):Number of Inputs: 1VESA (HD15):Number of Inputs: 1
Requires M1 to VGA cableS-Video:Number of Inputs: 1
4-pin DIN, no progressive supportComposite (RCA):Number of Inputs: 1
Video onlyStandard Definition TV:Inputs: Component RCA, S-Video, Composite RCAEnhanced Definition TV:Inputs: HDMI, Component RCA, M1-DAHigh Definition TV:Inputs: HDMI, Component RCA, M1-DAComputer:Inputs: M1-DAHDCP Support:YesStereo RCA Jacks Inputs:NoStereo 3.5 mm Mini-jack Inputs:No12v trigger for motorized screens (3.5 mm mini-jack):YesProjectorNet RJ45 Port:NoProjector Controlrojector Keypad
[SIZE=+3]Compatibility:[/SIZE]Data Compatibility:640 x 480, 800 x 600, 1024 x 768H-Sync Range:Not AvailableV-Sync Range:50 - 85HzVideo Compatibility:Full NTSC, PAL, SECAM, 480i, 480p, 576i, 576p, 720p, 1035i, 1080i, 1080p/24, 1080p/30, 1080p/50, 1080p/60
[SIZE=+3]General:[/SIZE]
Actual Dimensions:Height: 4.7 in
Length: 14.2 in
Width: 14.2 inActual Weight:9.3 lbs
Operating temperature:
(at sea level)50 - 95° FMaximum Altitude Supported:7500 ftTypical Power Consumption:250 WattsMaximum Power Consumption:300 WattsPower Supply:100 - 240 Volts at 50 - 60 HzMenu Languages:English, French, German, Italian, Japanese, Korean, Norwegian, Portuguese, Russian, Simplified Chinese, Spanish, Traditional ChineseApprovals:UL, c-UL, TUV GS, GOST, C-Tick, NOM, IRAM, FCC Class B, ICES-003 Class B, CISPR22/EN55022, EN55024/CISPR24, CB certified in accordance with IEC60950-1/EN60950-2, MIC, CE, CCC, VCCI, WEEEThe projector is brand new in the box! 0 hours on bulb!
Roll the Credits:
The Perfect Match:
Length: 14.2 in
I have removed the UPC and 1 serial symbol for promotional purposes.
