Viper87227
- Jun 2, 2004
I am the original owner, purchased it right when it came out. So, the phone has a bit over a years worth of use on it. I paid off the remaining EIP balance and the device has been unlocked by T-Mobile.
What you get is the phone, original box w/ manuals and sim card tool, original wall charger (not original USB cable though), a white OEM LG window case (lightly used), and a white Spigen Slim Armor case that is brand new in the packaging. The phone has a screen protector applied.
Cosmetically, I'd call the phone a 7/10. The front is nearly pristine. No scratches on the screen (although there are a ton of them on the cheap screen protector, so I'd advise getting a replacement). Bezels have very minor wear in the corners. Same goes for the sides, very minor light wear, but overall looks very good. The only area where the phone has cosmetic issues is on the back. I used a case for a while that left a gap between the back of the phone and the case, and dust got between them and scuffed the heck out of the back. I did my best to get pictures. It is much more noticeable in bright light, so I took pictures both with and without flash to try and give as accurate of an idea as I could as to how it looks. All the scuffing is from a case, the phone was not dropped, abused, rubbed with sandpaper, etc. Stupid case. The LG logo also fell off of the back, and what is left is an indentation in the plastic where the logo should be. So, I'll be very clear, the back of this phone is not pretty. Thankfully, like I said, all the parts you'll be looking at most of the time still look great, and if you use a case and a new screen protector, everything should look almost new.
The phone is rooted and has TWRP installed. It currently has a modified G3 rom installed. I can leave it as is, or I can return it to stock before shipping it. Please note that if you buy the phone and start flashing roms and break something, you are on your own. The phone works great right now, but you're on your own if you start messing with it and do something wrong.
Pics (huge):
http://imageshack.com/a/img673/4277/C77MuT.jpg
http://imageshack.com/a/img537/761/6ySx6a.jpg
http://imageshack.com/a/img905/6177/0RaNF2.jpg
http://imageshack.com/a/img673/6707/RSUbQN.jpg
http://imageshack.com/a/img537/4696/BW5tQS.jpg
http://imagizer.imageshack.us/a/img673/4049/mSpNsX.jpg
http://imagizer.imageshack.us/a/img903/7774/cLVoGd.jpg
http://imageshack.com/a/img904/1176/ptVP0x.jpg
http://imageshack.com/a/img540/7774/KPMmJ0.png
I'm looking for $215 shipped for everything. Heat under Viper87227.
Pics (huge):
