Title pretty much sums it up. If you want a tiny footprint, attractive case while using your SFX Power supply and Longer GPU then look no futher.
This is the Velka 7 by Velkase. This is a very hard to find case but i'm not reflecting that in my pricing.
Details on case, cooler can be found here: https://www.velkase.com/products/velka-7 and here: http://www.idcooling.com/Product/detail/id/205/name/IS-47K
It was built in twice. I ran both AMD and Intel with Gigabyte B550 ITX/3600x w/Nvidia FE 2070 Super and recently a MSI Z490 Unify ITX/10600k w/Evga 2080Ti Black Gaming.
Both ran great. For cooling you are stuck with using max 47mm max height so I used a Noctua NH-L9a-AM4 Chromax with great performance on the AMD 3600x and for the 10600k i've tried a couple of coolers as this CPU tends to run hot, I did use the IS-47k with the Nocua Fan and it was "ok" for regular use but Cinebench runs will bring it to uncomfortable levels in the 90's which I didn't like...so moral of the story, I would stick with cpu's lower TDP's. with this case based on the max cooler size you can use.
SHIPPED to ivoryg37
1. Not looking to trade
2. Will not split up as I have no need for both and you're basically getting the cooler and noctua fan free.
3. Only CONT US shipping and will priortize local to 13413 and or East Coast as it costs much much less for me to ship.
PM or msvirtualguy at gmail dot com.
Heat is in my sig. PICs below.
SHIPPED to ivoryg37
