I'm moving to the U.S. on Sept. 1 and can't be bothered hauling all this cruft, so anything that doesn't sell before then is going directly to Goodwill. Parts shipped from Ottawa, Ontario, Canada to anywhere: you choose & pay for shipping method (or local pickup near Carleton). Heatware is here, if that's still a thing.
Watercooling gear.
I collected all this over about 3 years of tinkering. None of it has been used since ~2009. I may part out if you want a few things, but I'm not interested in shipping one item at a time. All fittings are 1/2" The whole set is yours for $125, which is probably about half of what it's worth parted out. All these items are a little dusty, but in perfect working order.
Fans:
120mm:
2x clear Antec 3-speed w/ 3-pin headers $5 each
1x Xigmatek AD1212DX w/ 4-pin PWM header $5
1x Panaflo FBA12G12M (37mm tall, 86 CFM) w/ 3-pin header $10
2x wire guard for 120mm fan, free with any other purchase
80mm:
1x Protecnic MGA8012MS w/ 3-pin header: $3
1x Panaflo FBA08A12L w/ 3-pin header: $3
1x Yate Loon 8025M w/ bare leads: $3
My circa 2003 pride and joy overclocking system, or at least what's left of it. Sold!
Assorted stuff
Zoom X3 5660 ADSL modem: $30. Specs here (PDF). Comes with one filter.
I have tons of cables (ATA, SATA, CAT5), adapters (VGA-DVI, ATI Radeo breakout cables, laptop ATA-ATA), screws, etc. That's all free to a good home.
Watercooling gear.
- Laing D4 pump w/ computer power adapter
- Swiftech MCP655 pump.
- PolarFLO TT W/ mount for P4s/A64s. The mount is quite large, so I suspect you'd be able to drill holes for other mounting systems as well.
- PolarFLO universal chipset/VGA block (this one)
- DTek FuZion w/ both mounting brackets
- SilverProp Cyclone Fusion HL
- 240mm radiator w/ a few bent fins
- A set of 8 machined copper ramsinks w/ thermal tape (new in box)
- approx. 8' of ClearFlex 60 tubing
- a plastic Y-connector, plastic T-connector, and some assorted clamps
Fans:
120mm:
80mm:
Assorted stuff
