Slimline 'Single Board Computer' box:
Front panel with logo
Back with IDE controller card (one external channel, one internal) and external power connector showing.
Inside, top view
Inside, side view
Edit:
Hmm... looks like I forgot to take pics of this one closed, so here's some pics of my Smoothwall box (identical to this one except I drilled holes in the top to mount a harddrive)
Top Closed (remember no big screws on the top of the one I'm selling)
Top closed, with CD for size reference
Takes Socket 370 processors (supports 100MHz bus officially, but goes up to 150MHz in small increments). 1 DIMM (likes PC100 over PC133) slot. 2 PCI riser (removable). PC104+ connector (can't operate at the same time as PCI). Onboard i810 Video, PS/2 keyboard and mouse (does not halt at bootup if keyboard is missing, making it great for firewalls, etc.), 10/100 Ethernet port on the front panel. Headers for 2 USB (1.1 I presume), 2 serial, 1 parallel, 1 GPIO, 1 IDE, mutant floppy connector (smaller pins than normal, listed as 'reserved' in the manual).
Has dual channel IDE controller (disables internal IDE) with one internal and one external connector.
Controllable external power connector (hooks to parallel port header)
Used to be am IDE harddrive tester in a past life.
Primarily looking for trades, but $100 price set for rule compliance.
PSOne LCD:
4" PSOne screen with car power adapter.
Works good, it's just not compatable with the 'RGB' mod for connecting to a PC, and I don't have PSOne. It has rear A/V connectors (which is what it's using above, hooked to a Dreamcast). Has retail box. You could hook it up to a PC using TV-out though (did with my Geforce).
I'm pretty sure the blurryness is just my camera trying to capture a moving image.
$25 shipped to the US.
Wanted (in trade):
128MB sticks of ECC EDO DIMMs (might take smaller)
128MB or larger sticks of ECC SDRAM DIMMs
SCSI HDs and optical drives
400+Watt PSes
ATX cases
New wants: (3/7)
PCI card w/TV-out
IDE HDs 60GB+
I'm getting a couple of dual processor boards and need stuff to feed them.
Heat
Ebay
Email: tom61()sbcglobal.net <- also my PayPal address (or use the one listed on Heat)
Inside, top view
Inside, side view
Edit:
PSOne LCD:
Wanted (in trade):
400+Watt PSes
ATX cases
New wants: (3/7)
PCI card w/TV-out
IDE HDs 60GB+
Heat
Ebay
