Looking for suggestions. :\ I built a system using Gigabyte's GA-P35-DQ6, 4 sticks of Ballistix 1066MHz DDR2, G0 Q6600 with lapped Thermalright Ultra 120 Extreme, PCP&C 750W power supply, EVGA 8800GTX and the usuals (dvd burner, etc). All stashed in an older Stacker. Stock clocks and voltages since I live in a warmer climate and have two other systems running. Even with AC, it can get warm. Still, the Q6600 never went past 51C loaded.
Anyway, the first week to two weeks, I'd run Prime95 overnight with numerous 12+ hour runs without issue. I'm running 64 bit Vista and the latest drivers for everything I can. Last night I experienced my first BSOD in Vista after stopping a stalled Windows update. Since then, other apps seem to bomb that were once stable. With Prime95, one or more cores will stop after a few minutes. MemTest86+ V1.70 will fail memory test #5 with all four sticks installed.
I've tested each stick individually for 2 passes without problems. Two paired sticks without problems. Also slapped a pair in each channel pair. No memory failures in MemTest86+. But four sticks and it'll fail. So I don't know if it's MemTest86+ and a limitation with 4GB of RAM or what. Microsoft's memory tester didn't fail but who trusts Microsoft.
The mobo does seem to be using the right SPD settings and DDR voltage. Outside of trying a fresh install of Vista, I'm not sure what else to do as I don't have other hardware to do the swap and test game. Any ideas?
