I'm looking to get a laptop for gaming, but don't need one that will play Crysis. This laptop will be for Lord of the Rings Online, and strategy games like Civilization IV, Europa Universalis III, Hearts of Iron II and Dominions 3. The highest requirements among these games are a Pentium 4 2.8GHz processor and a 128MB nVidia GeForce 6800 or ATI Radeon X850 (must be DirectX 9.0c and pixelshader 2.0 compliant). What does a P4 2.8GHz CPU translate into for a Core 2 Duo in a laptop, and what comparable video card for the ones listed?
Doing a search in this forum for gaming laptops, it seems the general consensus is to get a Dell laptop. Looking at the current Dell specials, they have an instant savings of $314 for an Inspiron 1720 with an Intel® Core 2 Duo T5250 (1.5GHz/667Mhz FSB/2MB cache), but I don't know if that CPU is good enough. The best CPU option is an Intel® Core 2 Duo T7700 (2.4GHz/800Mhz FSB/4MB cache) for an additional $300, but an Intel® Core 2 Duo T7500 (2.2GHz/800Mhz FSB/4MB cache) is only an additional $175. The config begins at http://configure.us.dell.com/dellstore/config.aspx?c=us&cs=19&l=en&oc=DNDWMA2&s=dhs.
The screen is anti-glare widescreen 17.0" (1440 x 900). Is it worth $150 for the High Resolution, glossy widescreen 17.0 inch display (1920 x 1200)? I guess the benefit of that is full 1080p support, if I decide to use the laptop for Blu-ray movies.
The standard config comes with only an Intel Graphics Media Accelerator X3100. Options are a 128MB NVIDIA® GeForce® 8400M GS for $100, or a 256MB NVIDIA® GeForce® 8600M GT for $200. I figure the 8600M GT is probably the best deal? And that it's better than the required video cards mentioned above?
The memory is 2GB Shared Dual Channel DDR2 667MHz. Is that going to be enough to run Windows Vista Ultimate well? The only other options are 3GB for $125 or 4GB for $375, both 667MHz. I guess their bios is set for 667MHz and they won't change it?
Also, the 250GB SATA Hard Drive is only 5400 RPM, and I'm thinking a 7200 RPM hard drive would be best. They have an option for a 160GB SATA Hard Drive (7200RPM) Free Fall Sensor for no extra money, which I think would be better.
A CD / DVD+/-RW Drive is included with the standard config. One of the other options is a Blu-ray Disc Combo (DVD+/-RW + BD-ROM) for $160, which I guess would be nice for HD movies, but then I'd want to get the high res display option.
The wireless network adapter is an Intel® 3945 802.11a/g Mini-card, with an option for an Intel Next-Gen Wireless-N Mini-Card for $50. I thought the 'n' standard hadn't been set yet?
It has an option for Built-in Bluetooth capability (2.0 EDR) with a Dell Bluetooth Keyboard and Optical Mouse, all for $80. I figure that's not too bad for a full-size keyboard and mouse.
It has an integrated 2.0 Megapixel Webcam, which I doubt I would ever use, but no option to remove it and save some money.
The included battery is a 56Whr Lithium Ion Battery (6 cell). Is the optional 85Whr Lithium Ion Battery (9 cell) worth the additional $50? I don't know how those numbers translate into how many hours of use I'll get on a full battery charge, since they didn't have any info on that.
The included sound is High Definition Audio 2.0, with options for Integrated Sound Blaster® AudigyHD Software Edition for $25, and ExpressCard Sound Blaster X-Fi® Xtreme Audio Sound Card for $75. Unless I decide to use this as an HD-DVD player, I figure the High Def Audio is good enough.
So, starting from $1,099, with the following options I'm up to $1,704: T7500 (2.2GHz) CPU, Vista Ultimate, 256MB 8600M GT, Built-in Bluetooth with keyboard and mouse. The only other option I'm really considering is going with 3GB RAM for $125. I just can't see paying an extra $310 just to watch Blu-ray movies. I'm not even sure how well the 8600M GT would play them.
The system comes with a 1-year in-home service/parts/labor warranty. Is it worth $190 to bump that up to 3 years? Anyone have experience with these laptops and failure rates/times?
Any opinions, comments, suggestions? Is this system not enough, or overkill? Is there a better deal elsewhere? Does anyone have experience with a laptop from a boutique company, like AVA Direct, Velocity Micro, Maingear, or Puget? I know those companies put together good desktop systems, but I don't know how they rate for laptops.
One last question... does anyone think it would be good to hold off for a couple months, with all of the new CPU and GPU products coming out in January and February? I don't know if those products will affect laptops at all.
Thanks in advance,
Gary
Thanks in advance,
Gary
